ProviderConfiguration
The ProviderConfiguration section contains main provider settings that determine the connector authorization and behavior.
Most of the behavior settings can be overridden for specific connector objects and stored procedures in the Metadata section.
ProviderConfiguration section contains the following configuration sections and settings:
| Setting | Description |
| AuthorizationType | The type of web request authorization |
| AuthorizationToken | Section determining how authorization token is passed |
| BaseUrl | Initial part of the API URL |
| ResultPath | The path to the field that contains the result collection of JSON objects in the response |
| BodyPattern | The setting to configure the unusual web request body format |
| Headers | Defines the additional constant web request headers |
| FieldsParameterSupported | Indicates whether the connector supports querying only a part of the object fields by specifying the field list in a parameter. |
| FieldsParameterName | The name of the web request URL parameter which contains the field list |
| QueryAllFieldsParameterValue | Passes a full field list value in the request |
| DoubleFormat | Redefines the format of Double or Single data |
| DecimalFormat | Redefines the format of Decimal data |
| TimeStampStoreMode | The timestamp data format |
| DateTimeFormat | Defines the text format for DateTime data processing |
| DateFormat | Defines the text format for Date data processing |
| TimeFormat | Defines the text format for Time data processing |
| SourceTimeZone | Defines the source time zone |
| RateLimitThrottling | Section for configuring API limits usage |
| SubRateLimitThrottling | Section for configuring additional API limits usage |
| SortOperation | Section for sorting settings |
| PagingStrategy | Section for pagination settings |
| ErrorHandling | Section for error processing configuration |
| ReturningStrategy | Section for configuration of returned data processing |
| ConstantParameters | Section to configure parameters sent for all web requests |
ProviderConfiguration section example:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
"ProviderConfiguration": {
"BaseUrl": "https://api.stripe.com/v1",
"Authorization": "Basic",
"TimeStampStoreMode": "SecondsSinceEpoch",
"FieldsParameterSupported": true,
"FieldsParameterName": "opt_fields",
"ResultPath": "data",
"Headers": [{
"Key": "X-API-Version",
"Value": 2
"PagingStrategy": {
"Type": "LimitOffset",
"LimitParameterName": "limit",
"OffsetParameterName": "offset",
"PageSize": 100
"ErrorHandling": {
"ErrorMarkJPath": "ok",
"ErrorMarkConditionValue": true,
"APILimitMessage": "request over limit",
"ErrorMessageJPath": "error_description"
Authorization Settings
The following settings define the web requests authorization to access the source API.
AuthorizationType
The setting which defines how the connector will authorize the web requests.
Valid values are the following:
| Value | Description |
| None | No authorization |
| Basic | Requires the basic authorization parameters such as username and password |
| AuthorizationToken | The authorization is possible via authorization token |
| OAuth2 | Authorization via OAuth2.0 authorization protocol. |
For example, "AuthorizationType": "Basic".
AuthorizationToken
If you use the AuthorizationToken or OAuth2 type, specify how the authorization token is passed.
TokenName
Name of the parameter which accepts the token value.
TokenType
This setting defines the way to pass the token.
For example:
1
2
3
4
5
"authorizationToken": {
"TokenType": "Header",
"TokenName": "Bearer",
"HeaderName": "Authorization"
| Header | Token value is located in the header, such as Bearer Token in the Authorization header |
| UrlParameter | Token value is located in a URL as a parameter. For example, https://us11.api.mailchimp.com/3.0/lists?apikey=11111 where the 11111 is the token value |
| UrlPath | Token value is located in the URL as a part of it. For example, https://us11.api.mailchimp.com/*token*/3.0/lists |
HeaderName
Name of the header for the Header token type. The default value is Authorization.
General Settings
BaseUrl
The base URL is the initial part of the API URL. All API endpoints are relative to the base URL. For example, https://acuityscheduling.com/api/v1 or https://app.asana.com/api/1.0
ResultPath
The path to the field that contains the result collection of JSON objects in the response.
The field with the result collection of objects may be located on the root level of the data source response or nested within another object. For example,
Root Field ResultPath:
If the field is located on the root level of the response,
1
2
3
"data": []
Its ResultPath value in the connector will look like this
1
2
3
"ProviderConfiguration" : {
Nested Field ResultPath:
If the field is nested within another object,
1
2
3
4
5
response: {
data: []
You must specify it in the ResultPath, for example
1
2
3
"ResultPath": "response.data"
In the Metadata section, you can also define or redefine this setting for a particular object.
BodyPattern
Data sources APIs require passing the web request body in a specific format.
Usually, the data sources accept the web request body in JSON object format.
For example,
1
2
3
4
"firstName":"John",
"lastName":"Doe"
By default, the connector passes the web request body as a JSON object. Thus, you can skip this setting if the data source API requires passing the web requests body as a JSON object.
However, if the data source requires the unusual web request body format, you can define this format in the BodyPattern setting.
When the request body is an array:
1
2
3
4
5
6
"firstName":"John",
"lastName":"Doe"
Its BodyPattern will have the following format:
1
"BodyPattern": "[ <$body$> ]"
When the request body is an array inside the data property :
1
{ "data": [ { "name": "rndwork.com" } ] }
1
"BodyPattern": "{ \"data\": [ <$body$> ] }"
When the request body is a root object inside the data property:
1
{ "data": { "name": "rndwork.com" } }
1
"BodyPattern": "{ \"data\": <$body$> }"
In the Metadata section, you can define or redefine this setting for a particular object.
Headers
Constant HTTP request headers that are added to every request to the connector. Specify Headers as a JSON array of objects with the Key and Value properties. For example,
1
2
3
4
5
6
"Headers": [{
"Value": 2
Headers indicated in the ProviderConfiguration section apply to all REST requests in the connector.
If you want to apply a specific header to a particular object, you can define this setting directly in the Objects configuration section.
This settings determines if the connector supports querying only a part of the object fields. The list of fields is passed as an URL parameter in this case. This functionality helps to improve the API performance when reading objects. The default value is false.
FieldsParameterName
This setting determines the name of the web request URL parameter (or fields parameter), which contains the list of fields to query. Use this setting if the FieldsParameterSupported is set to true.
The default value is field. The name field is typical for most APIs.
You can define or redefine this setting for the particular object in the Metadata section.
Some APIs may require the fields parameter value and return an error if it is missing, or they may return only a subset of fields when the list of fields is not explicitly provided. In these cases, the connector must always send the fields parameter, even when all fields are requested.
If the API supports a special value that represents all fields (for example, all, _all, or *), specify this value using QueryAllFieldsParameterValue setting. The connector will pass this value as the fields parameter in the request.
If the API does not support a special value indicating "all" fields, the connector must explicitly list all available fields. This list can be provided manually, or you can specify the <~*~> value. In this case the provider automatically collects all object fields, builds the fields parameter value, and includes it in the web request.
DoubleFormat
This setting redefines the format of Double or Single data sent by provider to the source. By default, values are sent in the standard JSON format, but you can change it using this setting. See the available formatting options here. For example:
1
2
3
"DoubleFormat" : "g15"
DecimalFormat
This setting redefines the format of Decimal data sent by provider to the source. By default, values are sent in the standard JSON format, but you can change it using this setting. See the available formatting options here. for example:
1
2
3
"DecimalFormat" : "g29"
Date and Time Settings
The following settings define the format of date and time data passed from and to the source API.
TimeStampStoreMode
Format in which timestamp data is processed in the connector.
1
2
3
Possible values are:
| Text | Default value. Indicates that the date is processed in the text format. |
| SecondsSinceEpoch | This value indicates that the date is processed as a number of seconds passed since midnight of the 1st January 1970. This format has to be converted to DateTime |
| MillisecondsSinceEpoch | This value indicates that the date is processed as a number of milliseconds passed since midnight of the 1st January 1970. This format has to be converted to DateTime. |
You can also define or redefine this setting for the particular field in the Metadata section.
DateTimeFormat
This setting defines how to operate with the DateTime data. Use it when the TimeStampStoreMode = Text.
The default value is yyyy-MM-ddTHH:mm:ssZ.
To set the DateTimeFormat to MM-dd-YYYY HH:mm in all objects and all fields specify the following statement.
1
2
3
"DateTimeFormat": "MM-dd-YYYY HH:mm"
DateFormat
This setting defines how to operate with the Date data. Use it when the TimeStampStoreMode = Text. The default value is yyyy-MM-dd.
TimeFormat
This setting defines how to operate with the Time data. The default value is HH:mm:ssZ.
You can define and redefine these settings for the specific field in the Metadata section.
SourceTimeZone
If a source API returns dates in its own local timezone, while the date value itself doesn't contain the timezone, Skyvia cannot automatically convert such value in UTC. Use this setting to explicitly specify a source timezone. You can do that if the timezone is common, static, and it doesn't need to be selected for connection.
For example:
1
2
3
"SourceTimeZone" : "Eastern Standard Time"
RateLimitThrottling
RateLimitThrottling is an allowed number of API requests per unit of time. It helps to avoid the "429 Too Many Requests" error.
If the number of API calls reaches the limit per the specified time interval, the connector waits until this time ends and sends web requests afterward.
RateLimitThrottling works on a single connection and can't prevent the 429 error if there are several parallel connections to one source.
Example of allowing five web requests per 1 second:
1
2
3
4
"RateLimitThrottling": {
"RequestsLimit": 5,
"TimeInterval": 1000
The RateLimitThrottling setting contains two nested settings.
RequestsLimit
Maximum allowed number of web requests during the time span defined in the TimeInterval setting.
TimeInterval
Time span in milliseconds during which the maximal number of web requests can be sent.
SubRateLimitThrottling is used to configure additional limits on the number of web requests. Use SubRateLimitThrottling when source enforces more than one rate limit at the same time. This approach allows the connector to respect all API rate limits while maintaining the highest possible request throughput and avoiding "429 Too Many Requests" errors.
Like RateLimitThrottling, it has two nested parameters.
RequestsLimit
TimeInterval
For example, the Klaviyo API applies combined limits such as “1 request per second (burst) and 15 requests per minute (steady)”. In this case, the broader limit (15 requests per minute) should be configured in RateLimitThrottling, while the stricter limit (1 request per second) should be defined in SubRateLimitThrottling.
1
2
3
4
5
6
7
8
"RateLimitThrottling" : {
"RequestsLimit" : "15",
"TimeInterval" : 60000
"SubRateLimitThrottling" : {
"RequestsLimit" : "1",
"TimeInterval" : 1000
SortOperation
Defines sorting parameters that are shared across all objects. It helps to apply the same sorting settings to multiple objects.
Objects that are read through an aggregate relationship do not support SortOperation, because native sorting cannot be implemented for such objects.
The SortOperation setting contains nested settings:
Strategy
Defines how sorting information (fields and directions) is passed to the API request URL. Possible values are:
| SeparateDirectionParameter | When a URL contains separate parameters for the field name and sort direction. For example, &sort_field=id&sort_direction=asc |
| JoinColumnAndDirection | When a single URL parameter contains both field names and their sort directions. For example, &sort=person_id asc, updated_date desc |
| AscendingOnly | The API supports sorting only in ascending order |
| DescendingOnly | The API supports sorting only in descending order |
1
2
3
4
5
6
7
8
"SortOperation": {
"Strategy": "JoinColumnAndDirection",
"SortParameterName": "sort",
"AscendingValue": "ASC",
"DescendingValue": "DESC",
"FieldSeparator": ",",
"DirectionSeparator": " "
SortParameterName
The name of the parameter that contains the list of sort fields or joine field + direction values.
DirectionParameterName
Specifies the parameter name used to pass the sort direction for the SeparateDirectionParameter strategy.
AscendingValue
Defines the value for ascending sort direction. Default value is asc.
DescendingValue
Defines the value for descending sort direction. Default is desc.
FieldSeparator
The separator used between field names when multiple fields are specified. Default value is a comma.
DirectionSeparator
The separator between a field name and its sort direction for the JoinColumnAndDirection strategy. Default value is a space.
AllowMultipleFields
Defines whether the API allows sorting by multiple fields at the same time.
You can define or redefine the SortOperation in the Metadata section for particular objects.
PagingStrategy
Pagination is a technique that allows the splitting of the retrieved data into pages according to the defined strategy.
You must define the PagingStrategy if the source uses pagination. Otherwise, the source returns only the first page.
If the pagination differs from object to object, you can define or redefine the PagingStrategy in the Metadata section for particular objects.
Common Paging Strategy Settings
FetchAll
Determines whether all pages of data should be loaded into memory at once. Use it in the situations where the next-page token in a paginated API may become invalid too quickly. For example, while you are processing the records from the current page, the token for the next page may expire. As a result, attempts to read the next page can fail. Valid values are:
| True | Skyvia reads all the pages one by one into memory. Processing starts only when all the pages are read. |
| False | Skyvia reads page by page |
If you skip it, the default value is false.
InputType
This setting defines the way for passing paging strategy settings.
Valid values are:
| RestParameters | Default value. Settings are passed as URL parameters of the call, separated by the & character |
| UrlencodedBody | Settings are passed in the call body as key-value pairs |
Type
Determines the strategy type. Most PagingStrategy settings depend on the Type specified. The list of possible values is:
| Type | Description |
| WithoutPaging | No paging is used |
| LimitOffset | Page size and offset are specified. |
| PageNo | Page number must be passed in the request. |
| NextPageToken | The data source returns the token of the next page that must be passed in the request. |
| NextPageUrl | The data source returns the URL of the next page. |
See the detailed description of paging strategy types and settings required for them below
WithoutPaging
With this type selected, all the records return at once (when the source doesn't support pagination).
1
2
3
"PagingStrategy": {
"Type": "WithoutPaging"
LimitOffset
Use this type when records are requested in pages using limit and offset parameters.
For example:
1
2
3
4
5
"PagingStrategy": {
"PageSize": 100
LimitParameterName
Name of the Limit parameter. The default value is limit.
OffsetParameterName
Offset parameter name. If you skip it, the default value is offset.
PageSize
Defines the number of records selected in one call. For example, PageSize = 100 means that the first API call selects the first 100 records, and the subsequent API call selects another 100 from 101 to 200.
StartIndex
This setting defines the offset counting start (first page index). The default value is 0, but some sources require to set it to 1.
TotalRowsJPath
JSON path to search the total number of records on all pages. The reading continues until the total number of records is less than this value. Optional setting. It helps paging strategy more accurately determine when to stop retrieving data.
PageNo
Use this type when a web request must include the required page number. It is passed as the URL parameter of the request. The number of the next page is specified in every subsequent request.
This paging strategy supports different ways how the data source can indicate whether the next page is available. The data source response may contain either the indicator of the next page's existence or the total number of pages or the total number of records. Alternatively, if the data source does not return any such information, Skyvia can stop querying the next pages if the number of records in the received page is less than the specified page size. If page size is also unknown, Skyvia continues to query next pages till the current page still contains data.
Different settings are used for different ways of detecting whether the next page exists.
For example, it may look like this:
1
2
3
4
5
6
"PagingStrategy": {
"Type": "PageNo",
"PageNoParameterName": "page",
"PageSizeParameterName": "per_page",
"PageSize": 60
All the possible settings which may be defined for the PageNo type are the following:
PageNoParameterName
Name of the page number parameter in the request URL.
HasMoreJPath
This setting is used if the response contains an indicator that more pages exist. It specifies the JSON path to the response property indicating if the next page with data exists.
For example, the source response contains the following information:
1
2
3
4
5
6
7
8
9
"data": {
"pages": {
"hasMoreRecords": true,
"page": 3,
"totalPages": 10
In this case, the HasMoreJPath setting for the connector's paging strategy looks like this:
1
"HasMoreJPath": "data.pages.hasMoreRecords"
TotalPageCountJPath
This setting is used if the response contains the total number of pages. It specifies a JSON path to the response property with the overall number of pages. If the response doesn't contain the indicator of the next page's existence, reading continues until the page number is less than this value.
For example, ChartMogul source API returns the following pagination information in the object response:
1
2
3
4
5
6
"per_page": 50,
"page": 1,
"current_page": 1,
"total_pages": 4
Thus, the PagingStrategy for ChartMogul conector, will look like this:
1
2
3
4
5
6
7
"PagingStrategy": {
"Type": "PageNo",
"TotalPageCountJPath": "total_pages",
"PageSize": 50
TotalRowsJPath
JSON path to search the general number of records on all pages. If there is no HasMoreJPath value in the response, the reading continues till the whole number of records is less than this value.
Name of the request parameter which defines the page size (Optional).
If the default page size is known, but there is no corresponding name parameter, you can leave the PageSizeParameterName empty but specify the default number of records on one page as the PageSize value. In this case the connector can determine that the next page does not exist
PageSize
Number of records loaded per page. If it needs to be set in the request, specify it together with the corresponding PageSizeParameterName.
You can also use it to determine the end of reading if you don't specify HasMoreJPath, TotalPageCountJPath, or TotalRowsJPath. If you know page size used by the data source, you can specify it without the PageSizeParameterName. In this case connector stop requesting next page after it receives a page with less records than the specified page size.
The PageSize setting also has a special value -1, which means that the size of the page is unknown. In this case we do not pass the page size in requests. If you set the PageSize value to -1 and HasMoreJPath, TotalPageCountJPath, and TotalRowsJPath are not specified, the reading will continue until the number of records in the response exceeds 0.
StartIndex
The index of the first page. Default value is 1.
NextPageToken
Use this paging type when the data source returns the token of the subsequent page in the response body or header, and this token must be passed when requesting the next page.
1
2
3
4
5
6
7
"PagingStrategy": {
"Type": "NextPageToken",
"TokenJPath": "status.next_page",
"NextPageParameterName": "next_page_token",
"PageSizeParameterName": "limit",
"PageSize": 500
Name for the parameter used for passing the next page token in the request.
TokenJPath
JSON path to search the next page token in the response body. Required if the TokenHeaderName is not specified.
TokenHeaderName
The name of the response header, which contains the next page token. Required if the TokenJPath is not specified.
Name of the parameter which determines the page size. If you omit it, the request does not contain the page size.
PageSize
Number of records loaded in response to one call. It is desirable to determine the end of reading more accurately.
If it is not declared and PageSizeParameterName is not set, the reading continues until the request stops returning records.
If the PageSizeParameterName is set, the default PageSize value is 100.
NextPageUrl
Use this paging type when data source returns URL for reading the next page. It is returned in the response body or the header and is used as a URL for the next call.
1
2
3
4
5
6
"PagingStrategy": {
"Type": "NextPageUrl",
"UrlHeaderName": "Link",
"PageSize": 100
UrlJPath
JSON path to search the next page URL in the response body. It is required if the UrlHeaderName is not set.
UrlHeaderName
Name of the header where the next page URL is located. It is required if the UrlJPath is not specified. The header value looks like URL;rel="next". The response may return several values, but you need only values containing rel="next". If the response doesn't include the header with the rel="next" attribute, there are no more pages to read.
Name of the parameter which defines the page size. If not specified, the page size is not contained in the call.
PageSize
Number of records loaded per page. It is desirable to determine the end of reading more accurately.
If the page size is not defined and the PageSizeParameterName is not specified, reading continues till the call stops returning records or the URL for the next call.
If PageSizeParameterName is set, the default PageSize value is 100.
Prefix
Prefix that is added to the URL before reading the next page. For example, if the server returns the relative URL, you need to add the base URL of the connector.
Suffix
Suffix that is added to the URL before reading the next page. It may be some additional request parameters.
ErrorHandling
If the API request returns an error instead of a response, you can process it and determine the connector behavior in case of errors.
For example,
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
"ErrorHandling": {
"ErrorMarkConditionValue": false,
"ErrorMessageJPath": "error_description",
"ObjectNotFoundErrors": [
"may not be available",
"not found"
"HtmlResponseError": "Connection settings are invalid. Please check your Domain, User, and/or Password values.",
"FatalErrors": [
"The API call for this organization has exceeded the maximum call rate limit"
"Failover": {
"FailoverErrors": [
"Rate limited due to excessive requests",
"Too Many Requests",
"429"
"MaxRetries": 5,
"MinDelay": 500
ErrorMessageJPath
JSON path to search the message in the error response. You can specify several search paths separated by semicolon.
For example,
1
2
3
"ErrorHandling" : {
"ErrorMessageJPath": "meta.message"
Use the $full_error_response$ value to display the whole error response as it is. For example,
1
2
3
"ErrorHandling": {
"ErrorMessageJPath": "$full_error_response$"
If the value for this setting is not set, or it can't find the error message, then the search tries to find the error tags in the response. It starts with errors or Errors and then checks tags error, Error, message, Message, statusmessage, title, Title, Exception.
When Skyvia queries records with a filter by an ID value, it expects either a record or an empty result. However, some data sources return an error instead of an empty response when you request a non-existing record by an ID. In such cases we need to ignore this error and return an empty result.
By default, Skyvia ignores the messages with the Not Found, No Result found, Gone occurrences. Some data sources may return atypical errors. For such cases, you can specify a JSON array of error message strings to ignore in the ObjectNotFoundErrors setting, for example, "ObjectNotFoundErrors" : [ "may not be available", "not found" ]. The error is ignored if the error message contains at least one of the specified strings.
HtmlResponseError
Use this setting for the cases when the source returns the HTML page instead of an error message.
It allows replacing the HTML page with a readable error message. For example, Connection settings are invalid. Please check your Domain, User, and/or Password values.
In this case, all the error information sent from the source server will be lost.
ErrorMarkJPath
This setting defines the JSON path in the response, where you can find the error.
Use it if the source does not generate an exception in case of failure but immediately sends an error message in a field of the JSON response.
ErrorConditionJPath and ErrorConditionValue
Use these settings if the source returns a field with a sign that the request ends with an error instead of returning it.
In this case, you can specify the JSON path to search whether the execution failed or succeeded in the ErrorConditionJPath. And you can set the value which indicates that the request failed.
For instance, "ErrorConditionJPath" : "ok", "ErrorConditionValue" : false.
FatalErrors
Use this setting to define the array of the keywords inside the error messages which indicate fatal error. In case of such an error, the execution immediately stops without additional attempts to succeed.
UnauthorizedErrors
Use this setting to configure automatic retry behavior when a request fails. It contains an array of string pieces that represent error messages returned by the server. If the server’s error message contains any of these patterns, the connector treats it as an unauthorized error, it attempts to re-login and continue processing the request.
Failover
Use this setting if you want the connector to retry the API request if it failed with certain errors.
For example, many sources limit the number of API calls per unit of time. If this limit is exceeded (e.g., during the integration execution in Skyvia), the source returns an error, and the execution fails. Failover makes the execution run again automatically after such failure.
FailoverErrors
The array of string message parts of the server error messages that indicate that the execution must try again.
MaxRetries
The maximum number of attempts to retry the request. If all the attempts failed, an error is returned.
The default value is 10.
MinDelay
MinDelay is a minimal delay in milliseconds between attempts to retry a request.
By default, the minimal delay is 300 milliseconds. The delay is not constant and increases with the number of attempts using the exponential backoff algorithm. MinDelay determines only its minimal value.
ReturningStrategy
This section determines how to process the data returned from the data source for INSERT or UPDATE operations.
Use ReturningStrategy to configure returned data processing for both INSERT and UPDATE operations.
If INSERT and UPDATE operations require different returning behavior at the provider level, specify InsertReturningStrategy and UpdateReturningStrategy. They override ReturningStrategy in ProviderConfiguration and have the same settings.
If you need to override the ReturningStrategy settings for a particular object in the Objects section, specify ReturningStrategy in the corresponding InsertOperation or UpdateOperation in CRUD Operations.
ReturningStrategy section example:
1
2
3
4
5
6
7
8
9
10
11
12
13
14
"ReturningStrategy": {
"Type": "Row",
"ReturnDelay": 5000
"UpdateReturningStrategy": {
"Type": "Key"
Type
This setting determines what data is returned from the data source after INSERT or UPDATE. Valid values are the following.
| NotSupported | Nothing is returned. |
| Key | After inserting a record, the API returns only its ID. If there are other fields to return, another request has to read the needed fields using record IDs. It is recommended to have the RetrieveSingleOperation defined for objects with such ReturningStrategy type. Otherwise, the INSERT operation can take significantly more time. |
| Row | After inserting or updating a record, the response returns all the record fields |
ResultPath
Path to the returned data, if needed. For example, you need to specify it if the returned data is not on the root level of the response body, but is nested.
KeyHeaderName
This setting defines the name of the response header, which contains the ID of the inserted object. Use it when the record ID returns not in the response itself but in its headers. This setting is used only with the Key type.
ConstantParameters
You can set constant parameters sent with all requests for all the objects. This setting is needed when you have to pass the same parameters for every object, for example, authorization.
For example:
1
2
3
4
5
6
7
8
9
10
"ConstantParameters": [
"ParameterName": "club_secret",
"ParameterType": "UrlParameter",
"DbType": "String",
"Value": "CS-19195-ACCESS-WO0qRGel5fKZMnMSvDNKofmq4"
ConstantParameters is an array of JSON objects with the following settings.
ParameterName
Constant parameter name.
ParameterType
This setting determines how the values are passed in the web request. Valid values are:
| UrlPath | Value is passed as the URL part |
| UrlParameter | Value is passed as a URL parameter of the REST request |
| BodyParameter | Value is passed in the REST request body. |
DbType
Defines parameter data type. The list of possible data types is the following:
| Data Type | Description |
| Boolean | A simple type representing Boolean values of true or false |
| Byte | An 8-bit unsigned integer ranging in value from 0 to 255 |
| Int16 | An integral type representing signed 16-bit integers with values between -32768 and 32767 |
| Int32 | An integral type representing signed 32-bit integers with values between -2147483648 and 2147483647 |
| Int64 | An integral type representing signed 64-bit integers with values between -9223372036854775808 and 9223372036854775807 |
| Single | A floating point type representing values ranging from approximately 1.5 x 10-45 to 3.4 x 1038 with a precision of 7 digits |
| Double | A floating point type representing values ranging from approximately 5.0 x 10-324 to 1.7 x 10308 with a precision of 15-16 digits |
| Decimal | A simple type representing values ranging from 1.0 x 10-28 to approximately 7.9 x 1028 with 28-29 significant digits |
| Time | A type representing a time value |
| Date | A type representing a date value |
| DateTime | A type representing a date and time value |
| DateTimeOffset | Date and time data with time zone awareness. Date value range is from January 1,1 AD through December 31, 9999 AD. Time value range is 00:00:00 through 23:59:59.9999999 with an accuracy of 100 nanoseconds. Time zone value range is -14:00 through +14:00 |
| String | A type representing Unicode character strings |
| Guid | A globally unique identifier (or GUID) |
| Binary | A variable-length stream of binary data ranging between 1 and 8,000 bytes |
| JsonArray | JSON Array |
| JsonObject | JSON Object |
Value
Defines the constant parameter value.
Disable
The condition under which the parameter isn't used (for example, if the associated setting is NULL). It is usually used in conjunction with macros in Skyvia.
Example: ConstantParameters when Authorization Parameters Required for Every Object
For example, if a connector requires passing authorization parameters for every object, you can either add them to the Url setting of every object in the Objects section:
"Url":"/clubmembers?club_secret=CS-19195-ACCESS-WO0qRGel5fKZMnMSvDNKofmq4&club_key=HWGUG4xmhI7EWL7UOQ2Ew2V0vbmyjBUi2yfSOYoXCk"
Or you can configure ConstantParameters in the ProviderConfiguration section like this:
1
2
3
4
5
6
7
8
9
10
11
12
13
"ConstantParameters": [{
"DbType": "String",
"ParameterName": "club_key",
"DbType": "String",
"Value": "HWGUG4xmhI7EWL7UOQ2Ew2V0vbmyjBUi2yfSOYoXCk"
As a result, the URL setting for objects in the Metadata section will be simplified and will look like the following: "Url":"/clubmembers".
